maineiac5586
- Joined
- Feb 14, 2009
- 817
My 2000 ysnsha c40 tiller non oil injected REVS what seems to be super fast when cold started. Can someone confirm what rpm these should be turning when cold started before it automatically drops the rpm (part of the quick start procedure). Also when it kicks down to slow speed after cold start it stalls. It will restart right away and rev super high then stall upon kick down. Does this about 3 times then is fine after it is warmed up. Carbs have been cleaned spotlessly and quick START solenoid checked out fine on ohm resistance test and checking for needle movement when power is supplied to it. Please help it is an otherwise awesome motor
