Yamaha 50 hp 2 stroke oil pump bypass
maineiac5586
I have a 2001 yamaha 50 hp 3 cylinder 2 stroke. I bought it recently but the oil pump arm was not connected and the level sensor was unplugged. The seller didn't know much about it. If I pull the oil pump off does anyone know a part number for a block off plate and seal to put on the engine block where the pump was? I know yamaha oil pump systems are reliable but the guy who wants to buy this from me is ok prefixing his fuel. Thank you. Also does anything need to be done with oil level sensor to make sure I don't go into limp mode? As it is with sensor unplugged I don't hear any alarms
maineiac5586
I also would like to know if there is room to pull out the oil pump driveshaft with powerhead installed?
