DukesFin
- Joined
- Oct 12, 2005
- 502
I've got a Yamaha 50 TLRZ that started alarming today. Ran fine previously. I run in salt water but flush after every use.
Here's the deal... New impeller, housing & gaskets, all new seals in the lower unit. I've had it out 3 times since then with no issues and strong pee stream. This just started today.
I was told the oil system was disconnected but the tank is still on the motor (and FULL) right now and has been since I got it). I mix 50:1 as did previous owner.
I've got a Faria Tachometer so no digital Yamaha gauges to tell me if it's temp or oil.
Here's the odd part... It only alarms if I trim UP a bit. trimmed down (just past vertical) it is fine but go to try and trim it level, you guessed it... ALARM!
Any ideas where to begin my troubleshooting?
I've got no idea when the last time the thermostat was changed, or the poppit valve but thought I'd ask you folks first before I start breaking thermostat housing bolts off! Ha, ha!
Thanks in advance,
Duke
Thanks in advance,
Duke
