I just purchased a 2002 Lowe 160W with a 50HP Yamaha 2 stroke. The problem I'm having started the second time I took it out this year about 3 months ago. The engine starts up no issue just a little bit of smoke. I can drive it WOT 2 miles across the lake with no issue. I turn it off and Troll/Fish for and hour or two and it will start right up no issue. As soon as I get it up to plane WOT it will start to spudder and stall out. It starts right up and will run at half throttle just fine but as soon as as get it back up to WOT it will start to die again. I re prime the fuel bulb and it seems to take more pumps than usual to get hard. Once it gets hard again it will fire up run at WOT for about 30 seconds then start to spudder and die again. This seems to only happen after the boats sits turned off for about a hour. In the morning it runs just fine when I first start it up. I thought maybe a bad bulb and fuel line -replaced. Fuel Filter - replaced. Fuel pump - replaced. Not sure what to try next.
