Yamaha 70 hp 2 stroke misfires when warm
mtrafton
I have a 1986 Yamaha 70 hp, model 70ETLJ, 3 cylinder 2-stroke outboard. It started misfiring mid-summer after 30 or more minutes of perfect running. On subsequent trips the misfire started progressively sooner. Misfire now starts after about 10-15 minutes at operating temperature.
I ran it on the water this past week under load and by pulling one plug wire at a time found that the misfire is on cylinder 3. Switched coils around and made sure to correctly switch primary leads from cdi unit. Misfire still on cylinder 3 Switched spark plugs around. No change; misfire is on 3. The only difference between No. 3 plug wire connected and disconnected is that it "tries" to come out of the hole with the wire on the plug, with intermittent firing on No. 3 cylinder, but spark on No. 3 soon breaks down or goes away.
Here's what I've done:
All carbs cleaned and good fuel filter. New fuel tank and lines. New NGK plugs, correct model.
Checked compression when cold and got 120 psi +/- 5 psi on all cylinders.
Checked spark when cold and got well over 15,000 volts at each plug wire.
Replaced CDI unit with identical unit.
Removed all three coils and checked primary and secondary coil resistance both cool and when heated up. All are on spec, based on Yamaha manual.
I checked the triggers' resistance and got 130-135 ohm on all three (black to white/green, black to white/black, black to white/red). This is right to spec.
Checked the triggers' voltage when cranking engine, and got 0.6 volts AC. SPEC. for triggers with DVA is 2.5 volts.
QUESTION: Does the fact that I used a non-DVA meter but watched the readings carefully and they never went above 0.6 volts mean my reading is likely accurate, or do I absolutely need a DVA meter to get correct reading?
I checked stator resistance, brown wire to black and got 160 ohms, which is right in specified range. HOWEVER, the stator cranked only about 40 volts AC and the specified voltage is 140.. Again, is this reading taken with a digital non DVA meter, but carefullyl observed not to ever read above 40 volts in 5-10 seconds of cranking, accurate?
My gut is telling me that the stator-trigger assembly is at fault. But after chasing a CDI solution, I want to have solid advice from more experienced troubleshooters before buying more electronic parts. Yamaha ignition parts are reputed to be really reliable so I don't want to buy more of what I don't need.
Should I pull the flywheel and see what the stator assembly looks like? Any chance that a fault giving the above symptoms would be visible?
Since this motor starts right up and runs great for 15 minutes before the problem, am I right to believe that it is not a fuel system issue? Is there any other area besides ignition that it could be?
If you've worked through problems like mine, I'd appreciate your advice. Thanks.
99yam40
Pick up a DVA adapter to get reading to compare with spec in manual.
Take readings when running well and when problem shows up to see what has changed
Also your fuel pump is running off of the #3 crank case, check to see if it is leaking some fuel into the case causing too rich condition causing miss fire on #3
Are you sure your alarm system is working as it should?
could it be overheating or getting an low oil alarm
Check fuel pump 1st as that is my guess for eight now
mtrafton
HI 99yam40,
Thanks for the advice. Would I notice fuel coming out of the vacuum line to the fuel pump it if were leaking?
I am sure that motor is not overheating, as it's plenty warm but not scalding hot to the touch when it starts acting up. I forgot to mention that I put the temperature sensor in hot water on the stove, and it closed at about 165 degrees F. The alarm is working, as I touched the its + lead to ground lead and the buzzer in the control box up front went off. No low oil alarm, plenty of oil in oil tank.
Here's a question; The CDI pack has a yellow/red wire coming out of it, but I cannot find a wire that it connects to. Any ideas if that should plug into something that I'm missing? FYI, the yellow/read wire on the old CDI pack was similarly unconnected. My Yamaha manual doesn't even show a Y/R wire on the diagram, only a pink one for what the manual calls "Thermoswitch."
mtrafton
One other piece of info. Even when it's misfiring and acting up, the motor can still crank 3 or 4 thousand RPM but misfires and has big power loss. Does this eliminate the SAFE overheat system as a culprit?
99yam40
If the alarm work and is not coming in along with it hitting over 2K RPM then yes that can be eleminated.
Pull the pump off of the block, but leave the lines hooked up and then pump the primer bulb to see if fuel leaks from the pulse port on pump.
or take it apart and inspect the insides
mtrafton
Thanks for the instructions. I just checked the fuel pump and it leaks no fuel, even when bulb is really pumped up firm.
99yam40
Well sounds like you need to be testing with a DVA adapter to see what voltages are doing
mtrafton
Ordered DVA adapter and it'll be here in a few days. Will let you know what I find out. Meanwhile, does it make sense to remove flywheel and check for any obvious flaws in wires or stator-trigger assembly?
99yam40
You can do what you feel like , but I would not do it unless the reading told me to do it
mtrafton
Hi 99,
Lousy rainy day in NH, but got boat in the largest tank I could find, but cannot seem to reproduce the mifire due to lack of load, as I can't keep water in the tank while revving. However, using a Fluke 179 meter set for peak reading, and grounded to the black wire in the trigger harness, I got only 1.0 volts AC (spec is 2.5 volts AC) from all three trigger leads and 58 volts AC from the brown stator lead. Spec there is 140 volts AC.
Is that enough to conclude bad stator or something worn or frayed under the flywheel? It starts and runs fine in the tank without load. The misfire is under load on the water, as I mentioned before.
Any advice greatly apprecated.
99yam40
I am not sure what the 179 reads but, without the proper test meter or the DVA adapter with a regular meter you will not read anything to compare to the specs listed in service manual.
in other words your peak reading meter on AC will not give the proper readings.
I do know that with a DVA adapter the regular meter is set to DC
There are special meters made to read these outboard ignition systems
a little reading for you
http://www.outboardparts.com/trouble...printguide.htm
mtrafton
Got it. Fortunately I have a DVA adapter due in the mail tomorrow and will see what it gives me for readings.
Do I have this right?: A peak reading meter like the Fluke 179 is not necessarily a DVA meter and thus won't give similar readings.
Nowhere in the Fluke 179 manual does it mention DVA. It only says that you can measure min/max at virtually any AC frequency or voltage range, or any DC range.
Thanks.
99yam40
I do not know as I do not have a 179, but my 87 with peak reading would not get the proper readings.
My thoughts are if it does not have a DVA range it is not made for reading these systems
mtrafton
Thanks, I imagine that the 179, if it doesn't specify that it has DVA features, it probably doesn't.. Looking to get those DVA readings on the adapter today.
mtrafton
Hi 99, Got it out on the water today, a bit chilly but sunny and here's what I've got. All readings taken with DVA adapter.
Here is what I have
Got spec PEAK voltage off all components when cold: Stator, trigger coils and CDI unit. Good.
Got it out there and it took 15 or 20 minutes for the misfire to come, just about as usual.
Got good PEAK voltage on all triggers and stator after misfire started BUT?
Misfire was on cyl. 3. Easy to tell by pulling plug wires and noticing difference in the way it ran.
Switched coils misfire still on 3. Switched out plugs. Misfire still on 3. Even cleaned coil leads and ground lug. All shiny and have dielectric grease.
Misfire stays on 3 no matter what coil is connected to No. 3 cylinder. When I take the coil from No. 3 and connect it to No. 1 or No. 2 lead and No. 1 or No. 2 plug, there?s good hot regular spark on No. 1. or 2 respectively, jumping 20K volts on my spark tester. Even when I run it under load and get it to misfiring on No. 3. ON THE OTHER HAND, no matter which coil I connect for cylinder 3, the spark tester shows a weak very sporadic spark. No spark most of the time and every once in a while it?ll arc across the tester, but not as blue or big as on the other cylinders.
I'm suspecting something upstream of coils. Since the CDI pack is ?new? and the misfire is the same as with the original CDI pack, I feel it reasonable to eliminate CDI as cause.
BTW, No. 3 plug smells like fuel but is not soaked, and pumping the primer bulb does not restore normal operation under load when misfire is happening. I feel quite confident of fuel system being good.
Disconnected pink wire for overheat S.A.F.E system (or is it SLOW?) No change.
Would appreciate your insights. Thanks for reading this.
99yam40
I would be measuring the voltages from pulser coils, charging coils to CDI and CDI to ignition coils while miss fire is happening
to see if they changed from meeting specs when running well.
Too much fuel in a cylinder can keep a cylinder from igniting and burning fuel properly, but not sparking a plug in my opinion
mtrafton
Thanks, it sure seems that the pulser (trigger) coil or wires between charging coils to CDI or CDI to cylinder 3 are bad. Visual inspection of all these wires shows no fraying or worn insulation, even in the green/white No. 3 trigger wire, or any other wires to triggers or charging coil under the flywheel. Wish I had a spare trigger to put in place of No. 3, route its wire and put it in the harness. Will remeasure carefully after misfire starts if good weather here in NH holds tomorrow. Have you witnessed / experienced internal failure of triggers in your work? The magnets seem intact on all triggers. I wiped then clean and very gently passed 200 grit sandpaper over them. Hoping to get it wrapped up tomorrow. At least a spare stator from the same model and year motor, certified to work, is available to me locally.
Appreciate your assistance.
mtrafton
It turned out indeed to be the No. 3 pulser / trigger. Found a replacement stator assembly locally, installed it and the problem went away. I was pretty sure that with all the other components eliminated there was nothing else left in the ignition that could be the cause. Turns out my old CDI was fine, so now I've got some surplus. Just for poop and giggles I'm going to take put a ohm meter on the old trigger and heat it up to see if I can get it to lose proper resistance. Thank you for your assistance. While stators seem to be pretty reliable and not often the cause of misfires, this was a knotty case with an unlikely but happy outcome. Turns out that a friend of mine encountered a similar cause to a misfire on a relative's Ford Escort. The pulser coil wouldn't give a bad signal, but he replaced it and the misfire went away. Only later, with a ohm meter and a hair dryer could he reproduce the fault on a workbench.
Regards,
mt
99yam40
good to hear you are back in business
Thanks for reporting back what you found
