yamaha 70 hp no spark
darko1307
Help where to start. Today I was on my boat at cruising speed around 4000 rpm and suddenly my yamaha 70 1994. year just stop. After I removed motor cap I seen smoke from flywheel on top. After that I try to start it but whit no succeeds. I drag it home and try to see if there is spark and when I test there was not spark on any cylinder.
Where to start checking.
I am thinking on stator problem. If it is coil it would die one not all three at once.
Please any help would be god start.
Thanks!
99yam40
Re: yamaha 70 hp no spark
You need to find out where the magic smoke came out of. A service manual and the proper test equipment will guide you through the steps to locate the problem, but from what you have said it is under the flywheel.
