JPGBU1
- Joined
- Aug 8, 2010
- 30
I have an 88 yamaha 200HP outboard that a friend wanted me to fix up and sell. It has been sitting on it's side for 6 years and was not stored properly... also it only had about 100 hours on it when taken off the boat. The engine didn't want to spin without force. Lots of marvel mistery oil and turning it once a day for a week and now it spins around fine. I hooked up the controls and connected the battery and I checked the compression (WOT)and I had 147 PSI on the top two, 142PSI on the middle two, and 120PSI on the bottom two. keep in mind it is still wet from the MM OIL-is that good? ok? Bad? I know some yamaha's have different compressions for different cylinders. if it is good, next I will rebuild the 3 dual carbs and see if she fires. Also the water pump. Any other reccomendations? I also did the gear case oil and it was clean.
