anamealreadyinuse
- Joined
- Jan 28, 2012
- 65
I have a Yamaha 8 HP 2 Stroke that is not getting a steady stream of water. Today I took a can of canned air and tried to blow out from the input where you normally put the muffs and also from the output direction. I did this twice and it worked like a charm but within 10 min. I watched it slowly stop putting out the stream of water to nothing. The impeller/water pump was replaced within the past year but I have no idea if it worked before or not.
Is there a way to clean this out without pulling the unit? There appears to be a weed guard where you put the muffs, can I remove those and somehow vacuum or blow that out? I am not sure what is behind the weed guard? I believe the motor is a 2002 or possibly a bit older but it's never been run much.
What do you recommend? Thanks in advance for your help. FYI, I am a total newbie to marine engines so please be as specific as possible.
