I have my yamaha hooked up to cockpit controls in my sailboat.Over the weekend we had to motor an awful lot. When I came up to the mooring I slowed down, moved the throttle so that the speed and rpm were very slow and then it revved up by itself. I took off the kill switch so we would stop.I had been fiddling with the idle adjustment thinking it was idling too slow. But that wouldn't cause this problem,would it? Any ideas?
Second question, I have to pump the remote control lever several times in order to start the engine when it is cold. It will stay going only if the neutral throttle level is all the way up reving the engine high untilit warms up. Then except for the other annoynace the engine runs and sounds fine. Is this the sign of a problem? Thanks for any advice. Gerry
