Re: Yamaha 9.9 Compression
If both cylinders are within 10% of each other that is okay, BJS.
4 strokes usually come up higher than that but differences in guages and technique can cause the numbers to vary by as much as 50psi.
The probabilities that both cylinders have problems that lower compression to exactly the same level are about zero. One exception to this is a blown/leaky head gasket.
