yamaha 9.9 oil?gas?collecting under carb
Bearded Lady
After using my 9.9 kicker I tilt it out of the water. When I go to use it again a pool of gas/oil? has collected under the carberator opening. Also a skim of gas/oil? is constantly around the leg when down. Also the primer bulb never gets hard- just squishy firm - Needless to say the motor runs great. Starts first pull three times a week!
rodbolt
Re: yamaha 9.9 oil?gas?collecting under carb
is the oil level normal? if the check valves in the primer are not real good it can stay squishy:). check all the crankcase breather tubes. any vapors will collect and condense. you may have a problem and may not. any other symptoms ?
Bearded Lady
I have replaced the primer hose, tank, connections- the works. I thought this could be the problem, but unfortunately not. I chatted up the yamaha guys here in Victoria but they were a little stumped. If it is the breather tubes can I blow them out or should they be replaced. How can I diagnose ?
rodbolt
what is the model # and ill try to ID the system at work in the am
Bearded Lady
it's a 9.9 1994 yamaha 4-stroke I don't have a model number at the house but the serial # is 306615<br />(that S# looks a little short to me ) Thanks for your help. I am impressed by your posts 4428! Keep it up ! BoatAngel ?!!!
rodbolt
its an addiction :) :)
fordsrule56
TROUBLESHooot dont guess <br />if your in doubt bring it to a dealer DO It Right
bigbrownbuku
Originally posted by fordsrule56:<br /> TROUBLESHooot dont guess <br />if your in doubt bring it to a dealer DO It Right
i love fixing stuff customers screw up. usually it makes 2 problems. the original and whatever they broke fixing it. back on track. if you have a new primer and it wont go hard chances are you have a stuck open needle in your carb fuel bowl.<br />this would lend itself to easier starting of this engine because they love extra gas to get going. could be you are making oil too which will be a whole new set of problems if you dont take it to a dealer.
