Yamaha 9.9hp 4 - Stroke Upgrade to 15hp??
TROUTN
I have a 2005 9.9hp 4 stroke Yamaha that I want to upgrade to a 15hp. Is this possible?? I know I did it with the 2-strokes years ago and you just replaced the carb and reed plate. Is the upgrade possible with the 4 stroke or is it more complicated. I have to use a motor with a 9.9hp model number as the lake I fish has a hp restriction. The 9.9hp is just not enough hp to make my 17 ft boat work correctly. I have already tried changing the prop. Thanks
WillyBWright
Re: Yamaha 9.9hp 4 - Stroke Upgrade to 15hp??
You don't want to do that. Whoever patrols that lake will know if it's overpowered by how it runs out. It's usually the difference between planing or not. Any planing boat will automatically be suspect. You're painting a target on yourself and tampering would be an additional charge above and beyond the original ticket for overpowering. Besides, it's not nearly that easy anymore. :(
mjbrueck
Unless your 17 foot boat is extremely lightweight, a 15 probably wouldn't plane it anyway. The only difference at displacement speeds for a 9.9 vs a 15 would be the size of your wake.
vmaxkevin
I have a 12 ft. fiberglass boat with a 9.9 4 stroke Yamaha (2010). The boat weighs over 250 pounds and is rated for a max 14.5 hp. I weigh 265 pounds and that 9.9 will pick me, my 55 pound 6 year old and the boat up, plane it and do nearly 20 mph, so I disagree with the any planing boat will be suspect, comment. Although I'm not aware of how to increase the hp, I would suggest to you, the following...The 15 has a larger displacement than the 9.9. Overall displacement (along with stroke) generally translates into torque. Although you may extract 15 hp out of your 9.9, you will be unlikely to get the torque a 15 will produce, because there is about a 150 cc difference in displacement. Torque is what you feel on the throttle. The end result will mostly add up to a wasted effort. I stand to be corrected on this, but unless a 9.9 was just a detuned 15 (identical powerhead with a restricted carb), it's probably not worth the effort. What some guys do (and I don't advocate this) is to get a 15 and put a 9.9 sticker kit on it. As long as you respect the spirit of the law by not opening it up on a restricted lake, you wont draw any attention to yourself and you'll have the versatility of the extra power on other lakes. Your other, probably cheaper and lawful option is to buy yourself a lighter boat for your 9.9. Good luck.
