Yamaha 90tlr carb sync
camalot
Hi
I've just cleaned the carbs on my yamaha 90tlr and would like to check that they are in sync, I'm guessing there is a right way and a wrong way to to this.
Thanks Paul
99yam40
Re: Yamaha 90tlr carb sync
follow the steps in the Yamaha service manual for that motor
mrmamiller
99YAM40, I'm curious which manual shows the sync. Since I also have a 90TLR, I recently obtained the Yamaha service manual, already had the Yamaha operator manual. Neither has a procedure for the sync of the carbs. I found that the Yamaha manual was quite vague with regard to almost everything, as compared with OMC service manuals. Is there a better service manual than the Yamaha manual? FYI, my Yam svc manual is 18616-02-05.
99yam40
Mine was under chapter 3
periodic adjustments
Controls
mrmamiller
Ooops, guess I was looking under Fuel System for the carbs linkage stuff. You're right on the Periodic Adjustments. Thanks for the info.
99yam40
always good to read through the manual to see everything in your spare time.
Hard to find what you need when you need it
