Yamaha 90TLR -need to adjust carbs
freetime99
I have a 2008 - 2stroke 90 that needs low speed carb adjustment ( rough idling)
Can anyone send me the procedure to do this ? Thanks.
rodbolt
Re: Yamaha 90TLR -need to adjust carbs
there isnt any adjustments on the carb.
the air/fuel mixture screws have a plug over them.
if its idling rough odds are something is broke or the carbs are dirty.
the plug can be driled and removed if nessasary for cleaning.
scisgr8
The carbs are not difficult to take out and clean. I'm a novice and I did this on my boat and found that the float (needle) was stuck, cleaned them good and problem solved.
robert graham
Maybe check fuel pump for bad diaphragm, also drain each carb onto a clean white rag to try to get an idea for what water/debris may be in them. With drain plugs out, pump primer bulb to flush float chambers with fresh fuel. Carbs may need cleaning but you could check these 2 items first. Good Luck!
