Yamaha 90tlry water impeller change plus gaskets
199675hpforce
Ok got the lower unit off and put my compressor to lower plug. My results air is going out water impeller area real bad. I ran 25psi is this correct pressure. What parts will I need to order I checked out georgiawatersports they have water impeller kit but do not state whats included.
robert graham
Re: Yamaha 90tlry water impeller change plus gaskets
Why you put 25PSI air in lower plug? The impeller change kit comes with all new gaskets, wear plate, impeller, etc. Maybe you forced air past the drive shaft seal? Good Luck!
99yam40
You need to keep going in the other thread instead of starting a new one.
25 is too much pressure, and you need to pull the water pump to see the oil seals and they have nothing to do with the water pump kit
