If I remove the auto lube on 115 yamaha will carby jetting be the same
R rusdad Recruit Joined Nov 30, 2008 Messages 3 Dec 1, 2008 #1 If I remove the auto lube on 115 yamaha will carby jetting be the same
cousinabe Senior Chief Petty Officer Joined Nov 13, 2001 Messages 765 Dec 1, 2008 #2 Re: Yamaha auto lube remove Carb jetting should be the same. Why would you remove the autolube system? you are going to have to premix, etc... a simpler fix would be to use the new inline check valves(4) described in the conversion kit. http://www.boats.net/parts/search/Yamaha/Outboard/1984/115ETLN/OIL PUMP CONVERSION KIT/parts.html VALVE,CHECK [6R3-13183-10-00]
