yamaha C40 running hot
jl_photo
My 1996 C40 seems to be running hot. The warning buzzer keeps going off.
I have lots of water at the pisser. new water pump last season.
If I remove the thermostat housing, lots of water comes out at idle.
I tested and installed a new thermostat.
I tested the heat sensor in boiling water. it does not come on at 212 degrees.
I recently removed the head. It was clean inside and so was the water jacket.
I did not remove the side cover.
when the buzzer goes off the block is warm, but not so hot that I can't leave my hand on it.
The engine is on a tunnel hull. Could i be getting a little air trapped in the top of the cooling system?
jl_photo
Re: yamaha C40 running hot
???? I removed the thermostat and the buzzer is not going off now.
Yamajoe
Im not sure if this model has a grommet located in front of the thermostat, if it does, pull the grommet out and clean, flush the motor while you have the Tstat off; i wouldn't run the motor too long without a Tstat.
rodbolt
at 212 the temp switch should be closed.
double check your test procedure.
as far as water pressure simply install a pressure guage. especially since your running a unique hull.
pine island fred
You mentioned that you did not remove the side cover. Under no circumstances should you consider putting a wrench to those 12 or 14 bolts!
Trust me, you have adequate water flow around the exhaust. Look somewhere else. FRED
