Moonstation2000
- Joined
- Jul 14, 2013
- 26
So I bought a boat from my Dad after hearing nothing but good things about it, but so far it's been one problem after another. The most serious one is that the engine overheats. It has a good pee stream, but overheats at idle or running.
Today I ran it on muffs, checked the temps with an IR gun and when it got hot the alarm came on. The top cylinder is the hottest. Around 185 deg.
I removed the thermostat thinking it was probably defective and tried again with no difference.
Then I removed the entire thermostat housing. No water was coming out of the thermostat hole while the engine was running. It wasn't until the engine was about to sound the alarm that the water rose up to the thermostat level.
Does it seem that the water isn't circulating properly? Shouldn't I have water trying to come out the housing all the time while running?
I'm going to drop the lower unit and check the impeller next...
