Motor is a 2001 Yamaha F100.
The engine itself runs like a top, zero issues with that I believe. I just installed a brand new stock Yamaha 13.25X17 aluminum prop, as well as the spacer, bushing and castle nut on the prop shaft. I have a whine, not sure if you can hear it in the video, from 1000-1500RPM, it goes away after 1500RPM. But since changing the prop I now have this chatter all the way to 5500RPM, doesn't appear to go away. Performance of the motor doesn't seemed hindered at all. Still can get to max RPM, cruise at same speed, etc.
Ran it today off the trailer with the old prop and still had the same chatter. Not sure what it is at this point. I am purchasing a new drive shaft bushing and will be replacing it. I don't believe it'd make that clicking noise though, it'll help with the whine I'm sure. Bent prop shaft or drive shaft maybe?
Any help on what this noise may be? Thanks in advance.
Video Link: https://youtu.be/DwMGPG-qoQs
