The crank was seized and was believed to be the lower unit drive shaft and oil pump. It was running good in the fishing trip one day. When it was time to travel back, it got seized there.
I have lifted the powerhead. I have tried to crank with a wrench but failed to rotate it.
The oil pump and drive shift was in bad form too. The oil pump lower seal has corroded out and drive shaft stuck with oil pump shaft. The inner gear and outer gear of the oil pump stuck too and that's why the lower unit stuck there and can't be rotated.
However, to my surprise, the power unit crank still can't move. How hard shall I try to rotate it using a wrench? It was hanged in the air and hard to apply force though. I have tried my best but it doesn't move.
I will try to put it back to the lower and try again.
