Went on a sea trial for the 2002 Sea Pro 1900 I'm considering buying. Noticed the tach was jumping around a little bit when we first running out - didn't notice what the voltmeter was reading. Then after a stop for a few casts, we headed back in and I noticed the voltmeter was dead - pegged at the bottom. Then the tach was reading high, like 7000 rpm at WOT. The speedo seemed to be reading low from what I recall, but we were doing 42 mph on the GPS, which I thought was pretty good for the combo.
I've done some searching on this in the past and now since the ride. Most of what I've read seems to indicate this kind of problem usually happens with a bad regulator/rectifier or a bad stator. I'm not familiar with the Yamaha 4 strokes though as I've only owned 2 strokes so far.
Anyone with a Yamaha 4 stroke dealt with this one before? The owner thinks it's probably just a bad ground, but I'm a little skeptical having worked on stuff a fair amount myself (including a few Merc rectifiers) and finding that things don't usually end up that easy.
Thanks in advance, -Greg
