Re: Yamaha F115 won't maintain WOT
Just a post for future reference.
2006 f115 - 80hrs. on a Hurricane GS 190. We usually can squeeze out about 5900rpm/36mph
Well maintained, clean, covered and started regularly...but hadn't been out and seen an open throttle in about 8 months.
I had the same problem where the motor started and ran fine, up to about 3/4 throttle and then fell down to about 3500 any time full throttle was applied.
The first thought was bad gas, so we got some new spark plugs and hooked the motor to a 6 gallon belly tank and took it for a spin. We got a couple hundred more rpm, but were still bogging down at or near WOT.
I dug through some great information here and was able to begin trouble shooting under the assumption it must be the VST filter or an injector.
Being that it's in new condition, and the separator and sight cup are visibly very clean, we decided that it's more likely to be gum or varnish than it is physical debris. so, we hooked it up to the 6-gallon belly tank with a bottle of fuel injector cleaner in it...(follow the label and the professionals...might not be a good idea, but it worked for this one guy, this one time)
By the time we idled from the dock to the channel, it was already gone. the first hole shot was as good as new and we were off to the races. Ran the snot out of 4-5 gallons, hooked it back to the old gas in the old tank and rand the snot out of 20 more gallons.
We're back in business...4 dollars later!
Thank you so much for offering your professional knowledge to help like-minded people!
Innerwebz roxorz!
