Yamaha F115A - How to read the instrument?
Sarrre
Hello guys,
Can you tell me what the instrument is indicating? I don't have the manual for this instrument, so I cannot check what the symbols mean. However I shot a video, so maybe you can clarify this for me! The trim sensor is broken, so that's why it is all the way up. But I need help to identify the bottom symbols.
https://youtu.be/x7CWiIPXAhE
ClassicAQ
No Title
The 3 symbols at bottom of the tach LCD are oil level indicators. 3 solid bars under each symbol indicates good oil level in both main engine tank and reserve tank. 1 solid bar under far left symbol and 1 blinking bar under middle symbol indicates the oil level in the reserve tank is low. This is the alert you are seeing. Fill your reserve tank with oil and you'll then see 3 solid bars. See the chart below for complete details.
boscoe99
The tachometer is set to the two stroke mode. Needs to be set to the four stroke mode if used with an F115A. F for four stroke.
What the present indication is telling you is that the remote oil tank is empty. But there should not be a remote oil tank in the boat if an F115 is installed.
