Yamaha F150 Tilt
smitty477
Is it possible to limit the tilt angle on a Yamaha F150 if the steering gear is interfering with the transom?
Ldavidgrover
Re: Yamaha F150 Tilt
Yes you can . Look for the cam on the front where the motor tilts. The old cams were plastic and the updated ones are a metal. it has a single screw. Loosen it and turn to find where you need it to stop.
BaileysBoat
True, the metal cam is much better than the old plastic one. Problem is the adjustment cam is only used for the trim sensor reference and trim gauge calibration, and will not limit tilt or trim travel. A picture of the steering setup at the engine would help.
smitty477
"Problem is the adjustment cam is only used for the trim sensor reference and trim gauge calibration, and will not limit tilt or trim travel."
Good data as I have learned the past couple of days.
thank you
BaileysBoat
Sorry, can't make out the setup from the picture.
I had the same issue with the teleflex BayStar on the Stanley and was able to gain the req'd clearance by remounting the steering cylinder from below to above the steering arm.
