Yamaha F250A 6P2 – Code 72 Above 4000 RPM After Warm-Up
taka
Hello everyone,
I have a Yamaha F250A (6P2) and I am trying to diagnose an intermittent engine warning.
The problem occurs after the engine has warmed up and I run it above approximately 4,000 RPM.
Most recently, I was cruising normally at about 4,200 RPM when the engine suddenly dropped to around 3,700 RPM. Immediately after the RPM dropped, the engine warning indicator started flashing.
The warning flashes 7 times, pauses, then flashes 2 times. I believe this may indicate code 72, but I would appreciate confirmation from anyone familiar with this engine.
There is no warning buzzer.
After the warning occurs, if I try to run the engine above 4,000 RPM again, the RPM becomes unstable. It will rise and fall instead of staying steady.
Also, after the warning occurs, when I return to neutral, the idle speed is around 800–900 RPM, compared with the normal idle speed of approximately 600 RPM.
If I stop the engine and restart it, the warning disappears and the idle returns to approximately 600 RPM.
However, once the engine is already warm, the same problem seems to occur sooner when I run above 4,000 RPM again.
Parts replaced or swapped​
  • Swapped the PORT and STBD cam position sensors – no change in the problem.
  • Swapped the PORT and STBD OCVs (Oil Control Valves) – no change.
  • The OCV filters were swapped together with the OCVs – no change.
  • Engine oil was recently replaced.
  • Engine oil filter was recently replaced.
  • Thermostats have been replaced.
Checks already performed​
  • Fuel filter visually inspected – no obvious problem.
  • OCV resistance checked – both sides were approximately the same.
  • Cam position sensor connectors inspected – no obvious corrosion or loose connections.
  • Cam sensor circuit voltages checked.
  • Set the engine to 1TDCand checked the cam timing marks:
    • PORT side II–II marks align correctly.
    • STBD side I–I marks align correctly.
  • Timing belt tension checked – no obvious looseness.
  • Timing belt tensioner visually inspected – no obvious problem.
The engine otherwise starts easily and runs normally at lower RPM.
Because the fault consistently appears after warm-up and while running above 4,000 RPM, I am wondering if this could be related to the VCT system, oil passages, or another problem that only appears under sustained higher-RPM operation.
What would you check next?
Any advice from someone familiar with the Yamaha F250A / 6P2 would be greatly appreciated.
Thank you.
boscoe99
Are you talking about the warning coming from the tachometer?
Where on the tachometer are you seeing this?
taka
Yes. It is the engine warning icon in the upper right of the tachometer shown in the photo.
It flashes 7 times, pauses, then flashes 2 times.
I have been assuming that this indicates code 72. Is that correct?
99yam40
do you know what code 72 means?
i would be looking that up if I thought my motor was sending that code.
taka
Yes. According to the Yamaha service manual, code 72 is related to the PORT intake cam position sensor / signal.
That is why I swapped the PORT and STBD cam position sensors, but the problem remained on the same side.
I also swapped the PORT and STBD OCVs and OCV filters, with no change.
My main question is whether 7 flashes, a pause, then 2 flashes on this tachometer actually indicates code 72.
boscoe99
That tachometer does not provide fault codes.
You will need either YDIS of the winky blinky to get any codes that may be set.
taka
I have also attached a video showing the warning.
The engine warning icon flashes in a very consistent pattern: 7 flashes, a pause, then 2 flashes, so I assumed that this indicated code 72.
Just to confirm, does the number of flashes from the engine warning icon on this particular tachometer have no diagnostic fault-code meaning at all?
If that is the case, I will try to find a way to retrieve the actual stored fault code using YDIS or a diagnostic flash indicator.
View attachment code72.mp4
taka
Hi everyone,
Thank you for your advice so far.
The Yamaha Diagnostic System (YDS) that I ordered has finally arrived, and I connected it to my engine to check the fault codes.
The diagnostic history confirmed Code 72 – Cam position sensor (PORT INT).
Here is what I have checked and done so far:
  • Cam position sensors: Swapped the port and starboard sensors. No change in symptoms.
  • Oil Control Valves (OCV): Swapped the port and starboard OCVs. No change in symptoms.
  • OCV filters: Swapped the port and starboard filters and cleaned them.
  • Engine oil: Changed to genuine Yamaha 10W-30 engine oil.
  • Oil filter: Replaced.
  • OCV activation test: Used YDS to activate both OCVs. Both produced a similar clicking sound.
  • Intake cam timing: Checked with YDS at approximately 600 RPM (idle). Both port and starboard readings fluctuated slightly, but there was no significant difference between them.
  • Timing belt alignment: Checked the timing marks on the crankshaft and both camshaft pulleys. All timing marks were correctly aligned.
Current symptoms:
The warning usually occurs when running above 4,000 RPM after a long day of fishing.
During fishing, I normally leave the engine running at idle.
On one occasion, while cruising at around 4,000 RPM, the engine speed dropped to approximately 3,700 RPM, and the check engine warning light started flashing at that moment.
On another recent trip, I cruised at or below 3,800 RPM for over an hour without any warning.
When I was about 10 minutes away from the harbor, I increased the engine speed above 4,000 RPM. After approximately five minutes, the warning appeared again.
When the warning occurs, the idle speed increases from its normal 600 RPM to around 800–900 RPM and remains steady.
After shutting off and restarting the engine, the idle speed returns to approximately 600 RPM.
My question:
Despite all these checks and maintenance work, the problem associated with Code 72 has not been resolved.
What else could be causing this issue?
Has anyone experienced a similar problem with a Yamaha F250A or F300?
I would really appreciate any advice on possible causes, repairs, or specific checks I should perform next.
Thank you in advance for your help!
taka
did you do the 3 things listed in the pic you posted?
Thank you for your reply.
Regarding the three checks shown in the YDS screenshot:
1. Check intake cam timing (PORT) with Engine Monitor
I checked the intake cam timing using YDS at approximately 600 RPM (idle).
Both PORT and STBD readings fluctuated slightly, but there was no significant difference between them.
I have not checked the cam timing at higher RPM.
2. Check wiring for proper connection or damage
I inspected the sensor connectors and terminals when swapping the cam position sensors. I did not find any obvious corrosion or damage.
However, I have not checked the entire wiring harness between the cam position sensor and the ECM.
3. Check input and output voltage
I previously measured the voltage at the PORT intake cam position sensor connector using a multimeter.
With the engine cold and the ignition key ON, I measured:
  • Red/Yellow (R/Y) to Black (B): approximately 12V
  • White/Green (W/G) to Black (B): approximately 5V
However, I have not measured the sensor's output signal while the engine is running.
My question:
The problem is that the warning does not normally occur below 4,000 RPM.
Would checking the wiring and measuring the sensor signal with the engine stopped or at idle still be useful?
Or would I need to take these measurements while the engine is running above 4,000 RPM and the warning is occurring?
If testing under those conditions is necessary, is there a safe and practical way to do it?
What specific tests would you recommend next?
Thank you again for your help!
99yam40
I do not know how on that motor, but I would think testing while the problem is happening would be needed to compare to when everything is normal to see what is causing the code
taka
Yes, that makes sense. I agree that comparing the data when the problem occurs with the data under normal conditions would be important.
I'll see if I can find a safe way to collect the data and try it in the near future.
Thank you for your advice!
boscoe99
Check the electrical connectors. Would not hurt to clean them with electrical connector cleaner. Don't apply any corrosion protectant.
Would not hurt to disconnect and inspect the connectors at the ECU.
Clear the codes and then run the motor again to see what happens.
taka
Thank you for your advice! I'll check and clean the connectors, including those at the ECU, and clear the fault codes before testing again.
I'll let you know how it goes!
taka
Hi everyone,
Thank you again for all your advice.
I have some new findings after running another sea trial with YDS connected to my Yamaha F250A (6P2).
1. New findings during the sea trial
I ran the boat for approximately 30 minutes to allow the engine to warm up fully.
Then I increased the engine speed to around 4,500 RPM while monitoring the live data with YDS.
After approximately 4 seconds at this RPM, both the PORT and STBD intake cam timing readings changed to "-" (no values displayed).
At almost the same time, the engine warning appeared, and YDS recorded fault code 24 – "Cam position sensor (EXH)".
The engine RPM also dropped after the fault occurred.
I have attached a video showing the YDS readings before and during the fault.
2. Fault code has changed from 72 to 24
Previously, YDS confirmed code 72 – "Cam position sensor (PORT INT)".
However, recently I have been getting code 24 instead of code 72.
The latest YDS fault history shows:
  • Code 72: Cam position sensor (PORT INT) – 1326.1 hours
  • Code 24: Cam position sensor (EXH) – 1404.6 hours
The engine currently has approximately 1405 operating hours.
I have also attached a photo of the YDS fault history.
3. Engine temperature
During the test, YDS showed an engine temperature of approximately 96°C (205°F).
Is 96°C too high for this engine?
Could this temperature be related to the cam position sensor faults?
I already replaced the thermostats when I was first investigating code 72.
4. Electrical connectors and wiring
Following your advice, I disconnected and inspected the connectors at the ECU (ECM), as well as the cam position sensor connectors.
I also applied an electrical contact restorer spray (contact revitalizer) to the connectors.
I understand that this is different from an electrical contact cleaner, and that some contact restorers may leave a protective residue.
Unfortunately, the problem still occurs after these checks.
5. My questions
What concerns me most is that both the PORT and STBD intake cam timing readings change to "-" at almost the same time.
Could this indicate a common electrical problem, such as wiring, power supply, grounding, or an ECM-related issue?
Or is it normal for YDS to stop displaying both intake cam timing values when the ECM detects a cam position sensor fault?
Also, why would the fault change from code 72 (PORT INT) to code 24 (EXH)?
Could these two codes have a common cause?
Could the engine temperature of 96°C be contributing to this problem?
Based on these new findings, what would you recommend checking next?
I would really appreciate any advice from anyone familiar with the Yamaha F250A / 6P2 engine.
  • code24taiming.mp4
99yam40
I am not knowledgeable about this motor, but I would think that the ECU would send out a voltage to the sensors and they would send back a portion of that voltage for a reading.
see if that voltage being sent out to those sensors and any others goes away when this happens.
Just a wild guess from me
it is also strange that both cam sensors go bad but the system only alarms on one of them
boscoe99
What is your service manual indicating with respect to voltages to the sensors?
