Yamaha F25TRLY 25 HP 4 stroke year 2000 carb question.
TTravis
I've been having problems with my 25 HP 4 stroke F25TLRY running. I've cleaned the carb a few times which always seems to help.
I don't know the proper terminology but I will do my best.
In the lower carb bowl, there is a plunger that was stuck. After some prying, I was able to get the plunger out and clean things up with
carb cleaner. In the bottom of the plunger hole was a broken "snap ring"??? and one ball bearing. I don't think I lost anything.
My question is should there be more than one ball bearing? I only found one, but there are two smaller places where small steel balls might go.
Can anyone refer me to a diagram of this carb? It is a Kehin BCM 65W10B515.
Is this a standard snap ring I can get from an auto parts store? What size should I ask for? I do have a few pieces of what was a snap ring!
Any part numbers where I can buy what I need from IBoats would be greatly appreciated.
Jiggz
Re: Yamaha F25TRLY 25 HP 4 stroke year 2000 carb question.
You need to post this with the Yamaha Forum. This is the Force forum and you'll most likely to get better response at the right forum.
TTravis
Sorry, my mistake, I will repost over in Yamaha Repair section.
