seamanship
- Joined
- Aug 12, 2005
- 27
Yamaha carb kit 67C-W0093-02. This kit contains two parts I need help with, 14397-00 o-ring #30 on Yamaha diagram, 14335-00 plunger spring #21 on Yahama diagram.
It seems to replace the o-ring you have to remove part #46 on Yamaha diagram which is a plug. How do you safety remove this plug and can it be reused again? Should I just skip replacement of the o-ring?
Upon disassembly of the carbs mine does not contain a plunger spring. Is this part not necessary?
Yamaha carb #67c-14901-10-00. Actual on carb, Keihin bcm 67C10 NF19.
Would appreciate help with these two items. Have a Seloc book but these two items are not explained.
