yamaha f50 needs better hole shot
karlster
I have been lurking on this forum for a few weeks trying to get a better understanding of how to select the right prop to optimize performance.
So far I still have only a weak grasp of the variables.
My particular circumstances are a 1996 scout 153 sportfish with a yamaha f50. I bought the boat with a 10x15 aluminum prop that has a few nicks in it.
I have only taken it out in Monterey bay and there is usually surface chop and wind so my top speed is hard to pin down reliably.
Checking it with a gps I can get up to 25 knots pretty quick at 5400 rpm and with a smoother stretch of water and a bit of time the speed may hit 28 knots. Yamaha lists the rpm range for this motor as being 5000 to 6000 rpm. I feel confident in my ability to monitor the tach and keep it under 6000 rpm should underpropping it be best suited to my needs.
The problem is when I load the boat down with three adults and a few crab pots, the boat can barely get on plane and my throttle response at low speed leaves a lot to be desired.
My typical cruising speed is around 15 knots and I can't imagine ever needing to go over 20 knots in the kind of conditions I experience on the bay. I do plan on loading the boat down with a fair amount of weight on a regular basis. Furthermore next summer I can picture my 6 year old (as well as an occasional adult) being ready to try wakeboarding or innertubing behind the boat so I would really like to prop it for optimal hole shot and lower speed performance.
I have looked at the yamaha website and they have a performance bulletin for a f50 on a 16' smokercraft. It has a 10 5/8 x 12 prop and hits 5800 rpm at 32 mph.
This has me thinking of going for a prop with a pitch of 10 or 10 1/2. When I looked at the props on iboats site they show a few 10 pitch props in a 12" diameter.
I am hoping some of you can help me understand the pros and cons of going with a larger vs smaller diameter prop in my particular application and also make any pitch recommendations that might seem appropriate.
I am inclined to stay with an aluminum prop for right now as I have to pass over a lot of barely submerged rocks heading out into the harbors main channel and even if I don't hit a rock with the prop I imagine my brother or wife might.
I am also a bit overwhelmed by all the variety in manufacturers. Is it just a matter of buying from whoever has the dia and pitch at the best price or should I stay away from or seek out certain brand names?
thanks for any and all ideas
Karl
WillyBWright
Re: yamaha f50 needs better hole shot
Diameter isn't the big factor. Props come in families and the larger diameters are for a different kind of 50, the High Thrust models used mostly on pontoons and work boats. Those have different gearcases. The props won't fit your motor. You need to stay in the diameter range you're at. I would think that an 11 or 12 pitch would be appropriate for your application. 15 is too steep for anything but a very light boat with a very light load. Performance will very between manufacturers, but not by a lot.
Crownie2
IMO, you need to reduce pitch about 2 - 3".
As long as you watch the 6,000 suggested redline a lower pitch should be fine.
karlster
At this point I am leaning towards the Turning point Hustler 12 x 10.5. I will be disappointed if I don't underprop it enough that I have to watch the tach at WOT.
The only factor I forgot to mention was four blade vs three blade. I have so little understanding of 4 blade advantages that I will stick to three blade unless advised otherwise.
Thanks for the input so far.
karl
