Yamaha F6 Not Peeing
Rake722
Hi All,
I have a 2004 F6 and I recently changed the impeller and she ran fine and pee'd well.
She has not seen any use except for periodic warm up and she recently stopped peeing.
When the engine is then turned off I can hear air either leaving or being sucked in to the pee hole for a few minutes.
I'm about to remove the lower unit to inspect the impeller but thought to ask here first ?
I ran her again a few mins later and now there is no water coming from the pee hole.
Thanks in advance
Ron
99yam40
blow some compressed air up the Tell tail while running with water hooked up to motor
that may move things around if something is plugging things up
Rake722
Thanks for the reply, it was peeing strong when fired up so would it still do that if there was a blockage ? I will give it a go anyway
Rake722
I used a plastic WD40 pipe in the hole while running - worked a treat.
99yam40
I carry pieces of weed wacker line in my boat box and tackle box to run up the tell tail when it stops.
I get worried when I do not see a stream
