YAMAHA F80 NEEDS HELP
curtis1698g
I HAVE A 2000 F80 YAMAHA FOUR STROKE THAT I UNDERSTAND IS BASICALLY THE SAME AS A F100.<br />WHAT CAN I DO TO MAKE MY 80 TO A 100. COULD IT BE THE CARB JETS ???? woul like to know where to start is ther any help out there
Re: YAMAHA F80 NEEDS HELP
curtis1698g,<br />You'll have Alot better Luck,<br />Asking this in the Yamaha outboard forum....
jim dozier
I don't know what differences there are between the Yamaha 80 and 100 but I do know that the hp increase does not come from rejetting the carbs. Carb jetting on any engine 2 or 4 stroke is done to provide the best operational mixture for smooth running, takeoff and idling. Minor jet modifications may occur if it turns out the initial selection was a little too lean or too rich or if fuel grades change over the years. Putting bigger jets in your 80 will make it run rich and you will lose power and fuel mileage.<br /><br />Things that make a 4 stroke get more power revolve around better breathing. Anything that allows the engine to suck in more air or get it out easier and quicker. These would include larger intake and exhaust parts (ie manifold/header, carbs/throttle body, intake and exhaust valves, larger intake and exhaust ports, and increased cam duration and lift. Also modified combustion chamber shape and compression. Many of these modifications simply allow the engine to move the torque band up to a higher rpm which gives more horsepower. Some of these modification, such as combustion chamber design will get you torque and hp at lower rpms.
Jammu
They have different carb's. Look at Your dealer's part catalogue.
curtis1698g
YA-MAN <br />I HAVE LOOKED A A DEALERS CATALOG<br />THE ONLY DIFFERINCE THAT I CAN FIND<br />IS TWO JETS AND A NEEDLE VALVE<br />BUT I WAS STILL COURIOUS IF THIS WAS <br />THE ONLY CHANGE , CANNOT FIND RESTRICTOR<br />EXAUST BAFFELS OR ANY OTHER MOD.<br />DEALER SAYS NOT TO CHANGE JETS
curtis1698g
RPM,S 4800 MAX<br />13X17 SS PROP<br />18' CAJUN SPECIAL ALUMINUM<br />2 PEOPLE FISHING GEAR 4700 RPM
Vanja
Hello !
First post, but old already mentioned question.
How to increase HP, or how to transform F80 to F100, but this time we are talking about 2007 motor, without carbs - fuel injection.
Is the only differenc in CDI program, or there is olso/or some mechanical obstacle under exaust and/or intake collector ?
LP Vanja
