i am try to diagnose the cause of a small fire at the c.d.i. box. i have the new harness and c.d.i. box installed, but i will not fire the motor untill i can determine the cause. i have a yamaha manual on order, but recieved it. bummer.<br /><br />the lower plug melted with a red/black/blue/white wires and there is a small 1/4" diameter hole blown out the back of the epoxy coating an inch and a half in from the lower plug and about 1/4" from the edge of the housing. <br /><br />the owner wants me to fire up the boat, but i refuse to do it until the manual arrives.<br /><br />history..... i pulled the boat last fall and told him the nav lights where inoperable. the son-in-law 'repaired' the lights and installed a stereo which resulted in a dead motor. i replaced the 30 amp fuse on the main harness and the fire occured on their next outing. no wires where chaffed in the cowling, but i believe either the tach wire was tapped into at the helm or something has shorted out the ignition circuitry. i have not tested the coils, but i have never seen a bad coil set a control box on fire. would a bad bridge rectifier cause enough voltage to burn up the cd?<br /><br />can anyone help with the color codes at the helm for the stock yamaha gauges or give any insight. <br /><br />thanks guys. <br /><br /><br />red right return
