Re: Yamaha F90 4 stroke
Hi,<br />If You have a look at the Yamaha F90 Owners Manual You can se this (Maintenance, Specifications):<br /><br />Performance:<br />Full throttle operating range:<br />50006000 r/min<br />Maximum output:<br />F90TR 66.2 kW@5500 r/min (90 HP@5500<br />r/min)<br />Idling speed (in neutral):<br />700 ±50 r/min<br /><br />So You chould aim at approx 5500 rpm but up to 6000 rpm should be OK also at full throttle, assuming your tachometer is showing correct.
