Yamaha f90 starting issue
hycojake
My Yamaha 2006 F90 will not start unless I put it in neutral and move the throttle a little forward. Does this model have a choke. Any help appreciated.
boscoe99
No choke. That model is fuel injected.
Are you saying that the motor will crank but not start until you bump the throttle handle forward?
hycojake
Thanks for your reply. Yes it turns over fine but will not start until I put it in neutral and move the throttle a little forward. After a cold start it will then start okay and run fine. The only reason I mentioned the choke was I recently had to replace the ignition switch and it had a blue wire that I thought was for a choke.
hycojake
boscoe99
If I mentioned an idle air control valve would you know what I was talking about?
hycojake
I do. I replaced it about a month ago. Prior to that They replaced the fuel pump and serviced the housing that its contained within. I was having a problem with the motor running and then shutting down. After the engine cooled it would restart but then do the same thing again. As I mentioned earlier the engine runs great with the exception of having to give it a little throttle to start. I noticed this particular issue after the tank that contains the fuel pump was serviced. Are there adjustments from the throttle lever to the engine that could cause this.?
boscoe99
Carefully inspect the main engine harness wires to the IAC connector. The wires have been known to snag on the cowling when the cowling is being removed and getting damaged. Carefully inspect for any signs of damage. Might be hard to see.
hycojake
Thanks. My boat is at my storage location. I will inspect them next week.
tblshur
my cold start procedure is ; put gear shift in neutral push button in center of shift lever hold button in this allows you to advance throttle without it going in gear after warmup return shifter to neutral button will release push shifter forward it will go in gear hope this helps
boscoe99
If the throttle has to be opened to help start a fuel injected F90 then something is amiss within the motor.
hycojake
Thanks for your reply. Just a little more information. My original problem was the boat would be running okay and then just stall. It would not restart until the engine cooled. The service shop overhauled the tank containing the float chamber, intake seal, new fuel pump, needle valve, float and plugs. Quite expensive. Ran okay after that and did not cut off. Because it's on a pontoon boat and I have to haul it 50 miles to the service center a neighbor connected the diagnostic test equipment and it showed a faulty ICV. I replaced it and now it runs great except when starting I have to put in idle and open throttle. After the engine is warm it restarts okay. I have not been able to go to my boat dock to look at the wiring harness to the ICV but hope to next week. Sorry, I should have given the history of my problem before.
