Yamaha gears slipping
hollyj2
My 1998 Yamaha 9.9hp 4 stroke shortshaft with thrusting prop is operating ok up to about 1/3 revs. When I go above 1/3 the revs go up but the boat slows down. It only does it in forward. I'm guessing it is something in the gearbox. I recently replaced the water pump impeller (after which the motor operated fine. I have tried adjusting the gear linkage but it made no difference.<br />Any ideas would be appreciated.<br />Jason
rodbolt
Re: Yamaha gears slipping
hello<br /> I am guessing the prop hub is spun. if the gears were slipping your gear oil would look like liquid metal and soon after the first slip a lock up would usually occur.
hollyj2
Thankyou, I will have a close look at the hub,can you tell me what to look for and how to fix the problem?
bigbrownbuku
if you pull the prop and look at the back. there is a section of rubber between the spline and the base of the blades. sometimes it looks good but slips. a new prop for that engine is fairly cheap. a hub replacement might set you back half the cost of a new prop.
Trent
Another easy check is to get a magic marker and mark across the prop hub. Go use it. If the marks move, Then you know the prop hub is spun.
hollyj2
Thank's Gent's, <br />A new prop had been ordered.
