No more boats
- Joined
- May 4, 2023
- 59
OX 66
1999
2 stroke
250 Hp
fuel injected
compression all 6 cylinders 120
Dont know model #
ran fine , week later ran like crap ,
symptoms - not able too idle , not able too throttle up stalling before I could get into gear , - backfiring , - running like i was on 3 cylinders
Port side seems OK
Starboard side , no spark cylinders 1- 3 -5 , - then there is spark on random cylinder that had none , ( using a see thru tester that I can see spark )
swapped one of the no spark coil pak from starboard too port side . It had spark ,
Going from IOs too OB new too me ,
testing equipment really nothing , test light and cheap multi tester , credit card , and weekend warrior knowledge .-
Coil paks could be original,-
aftermarket 6 pak around $ 100 bucks , for Yamaha , max HP 225 . I have the 250 , any knowledge if they can be used ,? - see individual coil paks $ 89 , still indicating max HP 225 .
Educate me ,
STATOR - R there 2 pick ups - one each side of engine
Rectifier
I went thru all visible wiring , cleaned all grounds , dielectric grease , checked and cleaned harnesses
thanks in advance
1999
2 stroke
250 Hp
fuel injected
Dont know model #
Port side seems OK
Educate me ,
Rectifier
thanks in advance
