Re: Yamaha Injectors
Do not waste money, it is easy to clean Yamaha injectors.
They are just an electric valve.
You need a teeth brush, non agressive solvant (like methylated spirit, NOT ACETONE), 12V, compressor.
Immerse injector in the liquid, wash it with brush.
Connect it to 12V DC, you may heard the valve opening (if not it is died).
When opened, blow it with your compressor 8 bar (around 100 psi), you must see liquid stayed inside going threw out holes like a spray, insist if not.
A better way is to wash it opened (connected to 12V) in an ultrasound bath if you have one, like for eye's lens.
Now your injectors are new !
