RODNEY GOODING
- Joined
- May 30, 2017
- 4
HELLO ALL..................I have a problem with my engine which when ever the knock sensor is connected ................the engine drops cylinder power on power up and will not runn full power if I disconnect the knock sensor wire the engine runs great but idles high and I don't get full rpm as I use to get..................I already put a new cdi unit and new knock sensor and check wire between knock sensor and cdi unit all good..................I check all other sensors on the engine and they within the range as the book say it should be...........also I have the check light for codes...........there are no flashes..................can anyone help as to where I should go from here......................
