Removing my yami gauges and replacing with a custom flat panel lcd system. I have a question that I need some real in depth details. First, my speed gauge has the following wires, blue and black for the lights on one side,...the main plug has, double blacks, wht, dark grn, wht/blue, yel, red, and gray. Does anyone know the values of the sender such as ohms and volts? Also, another opinion on the wire color code would be helpful.
Now to the tach... Excluding the 2 for the lights, I have grn/wht, grn/red, pink, orange, blk/wht, blk, grn, yellow. Sending values and color codes would be great! Thanks a ton!
Basically, I need to know the values of the outputs for voltage and ohms so i can wiring my new gauge and program it to match.
