No more boats
- Joined
- May 4, 2023
- 59
Recently picked up GW with 2001- 250 yamaha - 2 stroke -
Familiar with IOs ,
OB new for me , getting familiar with this power package
Previous owner showed me invoice of recent work done Feb this year
impeller ,
VST - rebuilt
quart of gear oil - not sure if they topped off or changed ? ( takes more then a quart )
invoice indicated added quart gear oil ,not indicating changing, plus takes more then quart ,
Yesterday dropped oil too make sure it was clean ,
color was aqua , blueish , little water was visible as it mixed with gear oil
sat open over night making sure everything drained
Following day pressure tested ,
removed prop , hooked up pressure pump ,
pumped away , spraying soapy water on shaft seal , No bubbles
PSI held at 12 quite some time until I released
Knowing correct way is too removed and inspect lower unit but since impeller was recently replaced figured it was good ,
did notice drain plug & vent plug opened easily flat head , no pressure ,
Not uncommon for water intrusion thru screws or faulty gaskets,
purchased new O Ring gasket
My thoughts , since impeller was done by reputable shop , psi held on shaft seal no bubbles , I'm goona add new Yamaha gear oil , drain after few usage drain , take a chance ,
what do you think ?
Familiar with IOs ,
impeller ,
VST - rebuilt
what do you think ?
