Re: Yamaha OX66 stalling
I would check your fuses, you have a 20 and 80 amp fuse and by check replace with good ones. Usually you could go between the spade fuse on other motors and isolate the component. I usually use a high current shunt to check amps. If you have a voltmeter I think you have to set it to 20 amps dc and take off the negative lead off the fuel pump and put the black on that and the red lead on the fuel pump connection.
The one thing I don't like about Yamaha is that they don't list the amp draw under specifications. But a Mercury approximately the same pressure is about 4 amps. Also test the fuel pump resistor should be .53-.57 ohms. I got a feeling your going to need a manual...
Merry Christmas everyone...
Dear Lord Baby Jesus, I want to thank you for this wonderful meal, my two beautiful son's, Walker and Texas Ranger, and my Red-Hot Smokin' Wife, Carley...
