yamaha powertrim will not lower down.
timberman
hi all,
I recently put a new pump,seals,filter, and a couple of other
parts on my yamaha 60 feto powertrim. I bought the engine without the powertrim working so had never had it working before.
Now today we have added a certain amount of atf dexron oil and Im not sure how much oil is needed, I have filled the reservoir to about 70% with the powertrim/tilt laying horizontal on the working bench. There was still alot of air in the system so we tried to get that out and it seems to be oke now.
Now the powertrim works ok when trimming up but when trimming down nothing happens, the pump is running and when pushing on the tilt cilinder to simulate the engine weight it wont lower properly (maybe a centimeter when pushing hard). You have to turn the manual screw on the side and push it back in by hand.
Does anybody knows whats causing this problem? thanks in advance!
