yamaha pro 50 problem
kodied
Hello guys I have a yamaha 50 3 cyl i ran it today and it ran great for about 20 min. I slowed down from hitting a oyster bed and tilted it up, it cut off i cranked it back up and it would idle but when i put it in gear and gave it the gas it would cut off well i tried that a couple more times then it would'nt crank back up just turn over but not fire then in about 5-10 min. alarm went off. Any help plz!!
99yam40
Re: yamaha pro 50 problem
Always post model # of motor
Are you saying motor was not running but alarm sounded?
Do you have gauges to indicate what alarm is going off?
were you turning the key to on or to start when alarm came on? If so I would be checking the safety lanyard to make sure it is attached properly
kodied
motor was not running just in the on position and the alarm went off , i dont have gauges so dont no what alarm it is i will check lanyard thanks
