travis.hamilton
- Joined
- Jan 9, 2022
- 2
hey guys new to the forum, I have an odd problem with my Yamaha 50TLR 2008 year model. when running the boat, when I have been stopped for about 20 mins or more, the boat will crank and idle fine. but when you go to accelerate as soon as you get on the gas good the motor will die. after doing this 4 or 5 times it will get on plane and run fine. it is not a repeatable problem, it generally will happen only once or twice in a day.
It always is right after you crank it. It always will happen at the same point in the throttle, just as the throttle is contacting the cam arm on the CDI unit. It is always is after the motor has been off for a while. After it clears the problem it will not happen again as long as you keep it running. I suspect the CDI unit but really hate to spend $600 trial and error. The reason that I doubt it is the CDI unit is because when the motor is running no matter how many times you go to neutral back to in gear and accelerate it will not do it. does this sound familiar to anyone? any help would be greatly appreciated
Thanks
Travis
Thanks
Travis
