Yamaha Prop question VS2100
rbook101
I had a friend give me a VS2100 13x21p prop for my Yamaha F90. When I tried to install it on my motor the prop would not seat in the thrust washer. The thrust washer that's on the F90 was too large for the diameter of the VS2100 prop. After doing research on the prop it seems the prop came off a Suziki 90. At any rate, is there a thrust washer I can purchase to make this prop work? Or can I purchase a suziki thrust washer and make it work for my Yamaha?
Any input would be great.
Rbook
QBhoy
Do you mayne have a prop designed for the larger gear case motors ? Those dimensions might be more common on larger engines
