It seems that there isn't a lot of photo support regarding these Yamaha sterndrive units so I am posting pics of this stuff as I go. Any help along the way would be greatly appreciated.
I removed the outdrive and this is what I found:
How do I check the cable from this perspective? Should the slide on the top right move smoothly?
I'm assuming the shift fork is in the middle. Should it turn left and right smoothly with little effort? I'm assuming this remedy involves separating the upper and lower outdrive. Any special precautions in doing so? Is it pretty straight forward? Drain fluid, remove bolts, pull apart....
