Bob Gilvary
- Joined
- Apr 9, 2009
- 241
The problem started with the boat owner not being able to get over 3600 rpm's before the engine would stall out.
I changed spark plugs, and a new fuel water separator, then water tested. It ran better, got to the 4500 rpm range, then stalled out.
I checked out the high pressure fuel pump filter. It was clean. I took off the fuel rail to be sure some water had not accumulated in the bottom, it was also clean.
My fuel pressure gauge showed a constant 35# at all rpm ranges until it stalls, and once it stalls it takes several seconds for it to start again. It's like it has to wait to pressurize the system again.
I checked the fuel pick up at the tank, no screen on it. No anti siphon valve, new gas line from the tank to the fuel filter, new primer bulb. I've even been pumping the primer bulb when it stalled.
I tried to look at all the basic BS and be sure it was in good order.
Today's water test started out fine, until it got up to 4500 rpm's then it stalled and went down hill from there. Stalled at 3600, then stalled at 2000, then finally kept stalling when at idle.
Anybody have a suggestion, or answer as to what is causing this stalling?
