Re: Yamaha Tilt/Trim
I've had this problem as well. Here's what I've found, hope it helps:<br />1. Make sure battery is fully charged and connections are clean (if the motor was sluggish going up or down last time, battery may need to be recharged).<br />2. If your are charged, check your relays (see my post on July 2, 2003 - I got some great advice on what to check). <br />3. If you are charged and getting power at your relays, it may be the motor that activates the hydraulic pump.<br />4. If its the motor, the motor brushes may need replacing (i.e., you're going to need a mechanic to do for you - probably around $200 to do)<br /><br />Good luck
