Hey guys, I'm new to the forum...I see I have tons of interesting reading to do.
I have a 2002 Yamaha Vmax 150 (V150TLRB) on my Lowe Tahiti 224 deck boat. This past weekend I stuck the drain plug in the wrong hole and took on quite a bit of water. My auto bilge system didn't work so I have some troubleshooting to do there, but I was able turn the bilge on manually. After realizing the plug was in the wrong hole I decided to run the boat to suction the water out...I had to do this once in my jon boat and it worked great. I started the motor and accelerated. Just before getting on plane it stalled. Haven't been able to start it since. It turns over fine, just doesn't fire. No, I'm not writing this from my stalled/stranded boat
...we got it off the water with some help from a friend and his seadoo.
I checked the fuel filter and there wasn't any water in it. I checked the plugs and noticed some small "beads of water???" on the firing end of some of them. Not 100% sure that it is water. I also checked all of the fuses near the battery and on the engine...no opens and no high resistence.
The motor doesn't fire at all, but it does turn over just fine. I haven't checked to see if the plugs are firing and plan to do that tonight. Taking on water and having the engine stall seem to be related.
Any further ideas of what I could check? I have a manual for the motor.
Thanks in advance!
Thanks in advance!
