Re: Yamaha vs. Tohatsu
Hahahaha, trolls can't work a PC and I am uncapped what bandwidth is concerned, .... anyway .... like I said before, the standard tohatsu broke as well, not only the tuned and modified ones, the reason why you dont' see any claims like mine is because people obviously havent' tested the true performance and durability to make sure they last, like I did and trying to explain here, if it is so great then why not last longer? .... but what can you expect from a cheaper engine right? .... point is the way we handle these engines, why does the yamha last the longest, if tohatsu is such a good engine like you say why does it brake so fast?.... the boat deflated cause right after the motor seized, another boat went over it and chopped the left pontoon .... inflatable racers dont' buy tohatsu over other engines, they test the field to find a longer lasting engine and then all end up with a yamaha .....
