I have a 1998 225hp yamaha. I seem to have difficulty removing the yamaha weater separating fuel filter with the standard oil filter wrench.Is there any special technique I could use for this procedure without emoploying King Kong?
yep<br /> try using oil on the gasket at installation and hand tighten only. <br /> some models, racors in particular seem to get tighter all by themselves
King Kong may not be able to save you.Brute strenghth won't win this one.A good strong steady pull,sustaining pressure will usually work.<br /><br />And yes,oil the gasket on the next filter.<br /><br />DHP
